Home > General > Coming back to the fullfat fold
jambo27
Afternoon all,
After stupidly selling my L322 2 years ago (in a ill thought out tantrum wwhen the tax renewal came through Rolling with laughter ) I am looking to buy another one. Can't decide between 3.6 and 4.4 though. Been to look at an initially tidy 4.4 today with good body work, service history etc but on a quick peak under neath is exhibiting an oil leak issue as shown in the pic.
Predominatly over the middle of the back of engine and the OSF suspension arm - is this likely to be the famous o ring issue or is it more a walk away issue? I appreciate hard to tell from just a picture but any advice appreciated or any advice on where I should look more specifically to determine the issue if I go for a second viewing. 2008 TDV8
Post #693974 6th Jun 2024 12:34pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Probably you will have to buy it first then find out otherwise are you happy to get agreement of the seller to book it in somewhere for investigation at your expense!
Chances are it's oil cooler rings unless history shows it's already been done. However there will be other opinions. Anyway it's a great choice to grab a Fatty again ( go for 4.4, I love mine ) RR owner
Post #693975 6th Jun 2024 12:50pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Doesn't look like it's dripping so could be anything ranging from a bit of filling spillage to a small seep, but it's not dumping itself all over the road at least and you've got 9 1/2 litres to play with.
Subframe looks well corroded through so you should get that protected soon as.
I assume you took the undertray off. If not there's another tell tale sign someone's been in there already for some reason.
No clue as to why the susp arm would be wet whilst all around it is realtively dry, odd one that, perhaps brake fluid leak ?
Anyway, nothing in the picture worth walking away for in my opinion. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #693976 6th Jun 2024 12:59pm
DrRob
Oil cooler gaskets and O rings
Common issue seen often
Budget £1000 at an independent specialist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #693989 6th Jun 2024 3:12pm
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Deja vu!
I’ve just come back to the fold with a 2011 4.4 and had oil in the same place, I replaced the complete oil cooler and feed pipe o rings, also worth checking the coolant reservoir mine was black from the cooler itself leaking
If the seller will let you it’s possible to see the rear of the cooler and feed pipe by removing the pollen filter housing, plenty on here about it 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE
Post #693992 6th Jun 2024 3:22pm
107SW
Interesting comments re returning to fold! I sold my L322 a few months ago as barely use it ... am missing it & slightly browsing adverts!!
Of course, unsure whether I'd rather a L322 or L405 ...!!
Post #697827 11th Aug 2024 9:55am
