Home > Technical (L322) > Tracking Down Battery Drain, Volumetric Sensor
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Hi all,
Found some great guidance/posts on how to go about tracking down my battery drain.
My question; Does my 2008 3.6 TDV8 Vogue have an internal volumetric sensor as part of the alarm?
I need to set all the locks to get the car to sleep before pulling fuses from the passenger fuse box.
How do I lock everything to put the car to sleep without setting the internal volumetric sensor?
If I set this then I'll set off the alarm and wake up the car when I'm pulling the fuses.
Am I missing something?
Thanks for any help. All the best
Chris
Post #697381 3rd Aug 2024 9:00pm
mjdronfield
It does, and I believe that if you don’t double lock the car, it won’t activate, just single lock it.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #697382 3rd Aug 2024 9:24pm
Paddy X350
mjdronfield,
Thanks for that useful bit of info! All the best
Chris
Post #697384 3rd Aug 2024 10:50pm
Paddy X350
Actually if you press the lock button on the remote once, it sets the internal movement sensor. If you press it again with 10 secs it disables the internal movement sensor.
Just found the RR quick start guide which describes how you lock unlock etc. All the best
Chris
Post #697791 10th Aug 2024 3:19pm
mjdronfield
Yeah, it’s the other way round on the later cars, was trying to think back to my TD6. It’s all in the manual.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697802 10th Aug 2024 7:32pm
