Home > Technical (L405) > P400e not switching from combustion to electric mode |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 759 |
For several weeks, I had an issue with the oxygen sensor, which I kept clearing (P2275-00 Oxygen sensor signal stuck rich. Bank 1 - sensor 3). The sensor was replaced once in 2022 by JLR during a recall. Yesterday, after replacing it once again, the error disappeared. However, even though the vehicle starts in electric mode each time, when the combustion engine kicks in (sudden acceleration, etc.), it won't switch back to electric mode, unless ignition is turned off and back on. I initially thought this was related to the O2 sensor, but the problem persists. Has anyone with a P400e experienced something similar?
8th Aug 2024 1:38pm |
OK, so one day later it started working normally (as it did before the O2 sensor broke), maybe it’s because yesterday it was hotter (40°) and today it’s only 35° and the petrol engine was required for cooling?! Anyway, the switch between thermal and electric is happening now like in the good old days... |
9th Aug 2024 1:28pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 848 |
The petrol engine shouldn’t be required for cooling unless it has a fault. Should work fine in ev mode. My Previous RR's!
9th Aug 2024 6:46pm |
Yes, now it does. I thought it would perform similar to very cold temperatures, when the ICE kicks in... |
9th Aug 2024 8:09pm |
Yes, to delete the errors, the Autel MaxiAP200. |
9th Aug 2024 9:08pm |
OK, after two days of normally switching between electric and ICE, it started behaving like before, that is starting electric, but after switching to engine, it doesn't switch back to electricity unless the on off button is pressed. No errors this time, I am lost... Checked both 12V batteries, OK. Again, could it be the outside temperature, it's over 35deg? |
15th Aug 2024 5:17pm |
