Home > Technical (L322) > Charging, Discharging, Starting Help! FIXED |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Means one or more stepper motor's gone.
31st Jul 2021 7:59am |
Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51 |
Not sure what you mean by the complete output? I have the gap iid tool if that can be used to diagnose which ones are faulty. |
31st Jul 2021 9:10am |
yes you will need an output from the IID tool. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
31st Jul 2021 10:55pm |
Is it possible for R1 to get stuck?? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
16th Aug 2021 9:32pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2458 |
Are you thinking that the heat would be from the contacts or from the coil if the contacts are stuck closed? There's no feed-back from the contacts to the coil otherwise the coil would always be energised without any way to release the contacts. |
17th Aug 2021 1:27am |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
Have you got an interior light coming on due to badly a adjusted micro switch? Had that one, took me ages to realise the system did not shut down, kept cycling. It was in the glovebox which had dropped out of the track one side. |
17th Aug 2021 6:18pm |
s.ozer1991 Member Since: 28 Jan 2023 Location: Antalya Posts: 7 |
Dear friens,
28th Jan 2023 6:54pm |
I solved some of problems with removing HVAC. plug off all sockets and then plug in. There was probably loose contact. And after this process, problems has been solved.
9th Mar 2023 7:08pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8163 |
Well done on the fix... Pete
9th Mar 2023 9:59pm |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 74 |
I have AC that is very inconsistent in its delivery and have the below fault code:
6th Aug 2024 5:19pm |
