Home > Maintenance & Mods (L322) > Engine Mounts 4.4 TDV8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3252 |
That sounds like the gearbox splash sheild resonating which is much more common tha engine mount failure. 2012 TDV8 Vogue (L322) |
31st Jul 2024 7:43am |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 16 |
Is that the silver cover on the underside of the transmission sump? If so it’s not that, I took it off recently it’s not misshaped or loose. It’s tight and not fouling on it.
31st Jul 2024 8:03am |
You can download the full workshop manual from the Wiki section 2012 TDV8 Vogue (L322) |
31st Jul 2024 8:20am |
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 26 |
Got the same resonance issue and can feel it on the floorplate…espedially when the torque converter is locked, under load…have you eventually replaced the mounts? |
22nd Oct 2024 9:41pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Are the engine mount vacuum tubes still connected all the way to the mounts?
23rd Oct 2024 2:41am |
Theee is no mud and the tubes should be connected, I mean I was not able to check but there was absolutely no event justifying a discomnection. Could be split tubes though. Will definitely check. |
23rd Oct 2024 6:20am |
