![]() | Home > Technical (L322) > Number of Demanded Regenerations - anomaly / figure jumping |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I have always read your DPF related posts and respected your opinions.
steve916s Member Since: 23 Oct 2023 Location: Wantage Posts: 2 ![]() ![]() ![]() |
I can beat that!
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
haha brilliant answer - also Dr Rob concurs - thanks Mike! . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) Last edited by Range Rover L322 on 23rd Jul 2024 7:42pm. Edited 2 times in total |
This is helpful, thank you! If anyone else sees jumps like this, it would be good to know as well. . 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
Well, this is getting interesting!
the only time my demanded regens went up by over 1000 a day (sometimes) was when I had my inlet manifold replaced (was cracked, leading to RP) and they cracked the thermostat housing which made the engine run too cold (fan was on most of the time - I could hear it.) to complete a regen sequence.
I can only assume that if some parameter is preventing a regen then the ECU just keeps on putting in the request until the parmeters are met. This may be an anomoly of the GAP tool as number of completed regenerations should be the reliable figure rather than demands. 2012 TDV8 Vogue (L322) |
