Home > Technical (L322) > P023D-22 (2C) Manifold absolute pressure
EvolutionUK
Hi chaps, does anyone know what the 2C represents on this fault code?
Would a K&N air filter help throw the code?
Thanks
Matt
Post #697016 28th Jul 2024 10:31am
kevinp
Hi Matt, I put a K&N filter in a Ford Explorer and the oil mist off the filter kept clogging the MAF sensor. Put a genuine filter in If I was you.
Have you cleaned the MAP sensor? Don't poke anything in it when cleaning or you'll puncture the membrane inside.
Post #697019 28th Jul 2024 11:04am
pcourtney
Clean the MAP sensor with carb cleaner - don't be tempted to prod and poke into the 4 holes
Which TDV8 engine do you have 4.4 or 3.6 ?
If fault can be cleared after cleaning MAP sensor, then great, if not you could have a crack in your plastic inlet manifold ( over £500 each side to replace ) but can be repaired if its a small crack with Q-Bond - make sure it's completely clean, degreased and dry before applying Q-Bond ( rough the area up up with some 200 grit sandpaper before applying the Q-Bond )
https://maltings4x4store.co.uk/inlet-manif...-lr034993/
Post #697024 28th Jul 2024 11:35am
EvolutionUK
Thanks chaps. Great point regarding the oil mist Kevin. I hadn’t thought about it! I’m going to take a look at cleaning all the sensors. It has only happened a few times cruising with slight load. Codes can be cleared. Turning off the engine and re starting also fixes it, so I’m hoping it’s just grime build up as it was evident it had been a bit neglected. It’s the 3.6 08. I brought it to see what all the hype was 🥴
Post #697025 28th Jul 2024 2:15pm
