Home > Maintenance & Mods (L322) > 4.4 tdv8 LH air inlet manifold replacement
pcourtney
Phoenix wrote:
The 'special tool' is just a close-fitting round bar that goes in an injector port, every time I've done them I've just used two (clean!) injectors in alternate ports
@Phoenix - please could you kindly explain a bit further for me please the way you used new injectors in alternate ports so that you do not need the LR injector alignment tool ( round bar)
I have bought 2 new injectors and will be removing all 8 of mine soon ( and new injector copper seals at the bottom ) , and will be using an Injector Seat Cutter to make sure the bottom of the injector is perfectly flat, so am just trying to get everything prepared and organised before we start - thank you
Post #697022 28th Jul 2024 11:27am
