Home > Technical (L322) > Bad Oil Leak and Oil Filter Housing Block Assembly |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 786 |
@Kevin - but you also had oil needing to be topped up regularly until you cleaned the MAP sensor and it stopped, so far so good for me also
23rd Jul 2024 6:56pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1188 |
I think you've misunderstood what was wrong with mine. My filter drain valve had come off it's locating post and that was somehow flooding the intake system with oil. While it was like that my MAP sensor was clean but wet with oil instead of the usual sooty deposits.
23rd Jul 2024 8:16pm |
thx Kevin - I read your post "Something to check when you change your oil filter. After the filter is removed take a look in the housing and you will see what I think is a piece of metal that acts as drain valve that opens when you loosen the filter. When you put the new filter in and tighten it down, the filter presses on it to close the hole. When I did my first oil change this piece was displaced. It attaches on a plastic peg in the housing"
23rd Jul 2024 8:33pm |
Well cleaning the MAP sensor really helped, not getting the oil loss after 1000 miles, just a few drips on the driveway, opened the bonnet again this afternoon after a 200 mile trip and noticed oil where I have circled it Yellow, seems like where I took off the throttle body intercooler pipe and made a better fit with 3 large o-rings (circled in orange), the oil has now found a way to escape more towards the plenum, what would be a quick fix ?
28th Jul 2024 5:17pm |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 104 |
There is an O ring there. It's probably worth replacing. Part number LR022931
29th Jul 2024 8:49am |
