![]() | Home > General > Parking in Access height |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 612 ![]() ![]() ![]() |
Never heard that before, I always wait till stopped. However, I would advise against changing heights with the brakes (pedal) heavily applied because as height changes so does wheelbase / wheel rotation.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
I drop mine when I'm pulling on the drive so I don't have to wait for it to lower before getting out but always release the parking brake before altering the height up or down so not to put load on the brake shoes. |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
By all accounts its in the manual in bold text not to put it into access mode while stationary.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
This seems odd, as my car will automatically drop to access height when I stop the engine and open the door. Unless I’ve already hit the button before I stop. Got - 2017 SDV8 Autobiography in Loire Blue
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
the L405 after 2015'ish has the auto access mode option , the L322 does not.
That was always my philosophy Stan, use it or lose it |
also its worth going into off road occasionally , again to flex the rubbers..
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1558 ![]() ![]() ![]() |
For info, from MY2017 owner manual:
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 189 ![]() ![]() ![]() |
My 2016 drops when I take my seatbelt off |
Which manual is this? - mine doesn't show it and it says access height can be activated up to 40 second after the ignition is switched off as long as the door are shut. 2012 TDV8 Vogue (L322) |
@Stan,
Don't think those links are working hyper text wise anyways.
The other argument is that constantly rolling the fold will wear the rubber more. My fronts failed predominantly due to age rather than under or over use. 2012 TDV8 Vogue (L322) |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1036 ![]() ![]() ![]() |
I’ve always dropped the car to access mode before switching off the engine, that’s on my 2 x L320 RRSs, my L322 FFRR and the current L405. All had the odd trip off road too and I’ve never had problems with air suspension on any of those 4 cars. |
