Home > Technical (L322) > Hard start from cold
Danwilderspin
So my 4.2 supercharged was running fine up until about 6 weeks ago.
I did an oil service and noticed a split vacuum line to the LPG.
After replacing said line and doing the service it suddenly started doing long cranks every morning when I go to start her.
I really can’t see how what I did is connected?
Anyway since having the problem I had initially blamed the LPG so I have disconnected everything I can and disable anything else to do with LPG to rule that out. The fuel pump is only 4years/36k old so left that but did a filter.
It has decent rail pressure and waiting as the key is turned a few times doesn’t make any difference.
I should say that once started it drives exactly as normal as it should.
What am I missing here? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #696620 21st Jul 2024 9:45pm
dingg1
Try resetting engine adaptations
02 sensors may have drifted way out of whack with the vacuum leak.
Just guessing here, but worth a try 👍
Post #696624 21st Jul 2024 10:14pm
Danwilderspin
Forgot to say tried that multiple times to no avail - the problem was worse after running lpg which led me to disconnecting it but still having issues Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #696625 21st Jul 2024 10:37pm
