![]() | Home > Technical (L405) > TDV6 questions — crankshaft pulley |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 31 ![]() ![]() |
Video: https://imgur.com/a/jzyL4t1 |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 ![]() ![]() ![]() |
Hi,
And be careful to download videos from new members who only post a hyperlink. I personally would not open that |
It’s just Imgur which is a trusted source, possibly the #1 method to share photos and video links. You can copy and paste the link and inspect it if you doubt it. |
Also, if your noise is not present in park, def would suggest drivetrain. Maybe worth doing fresh fluids in tranny/TC/diffs? |
I did the transferbox double flush (and reset), and also did the gearbox filter and fluid (no full flush, but only the 4 litres that came out; will have to do some more times). Diffs not done yet, but on the list. Coming to an end of ideas and still no progression on that |
Sorry ash83 that I overlooked you are the original poster with a lot of info and after that you posted the video |
No worries! |
Update:
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2555 ![]() ![]() ![]() |
Does the new pulley jump about like the original? |
A bit less but similar. Think it’s run out (not perfectly round) |
Thanks.
It seems better. Just not perfect. |
