Home > Technical (L405) > 4.4SDV8 crankshaft dimensions
Hodgey26
Australia 2004 Range Rover HSE Td6 Adriatic Blue
Does anyone have the original dimensions for the bearing journals on the 4.4 V8 crankshaft?
I am in the process of rebuilding mine due to a failed bigend bearing and need to get the crankshaft ground, the machine shop don't have the spec's.
Post #696548 20th Jul 2024 1:31pm
workshop manual? ... - .- -.
Post #696549 20th Jul 2024 1:47pm
If they buy shells/bearings for a first regrind it should say on the box... Thumbs Up Pete
Post #696557 20th Jul 2024 5:15pm
Hodgey26
Thanks Pete, i will contact the bearing supplier tomorrow like you say they should have the spec's. they haven't ground the crank yet so i haven't ordered the bearings as i need to know if going oversize by 0.25 or 0.50 looks like i can get King bearings in both sizes!
Post #696570 21st Jul 2024 3:07am
Good luck... Thumbs Up Pete
Post #696591 21st Jul 2024 11:01am
