Home > Technical (L322) > Help needed please!
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Help needed please!
2008 3.6 TDV8
I think this started after changing the power steering pump.
Battery pre start-up 12.2V, 14.4V when running (i.e. all seems OK).
On first start-up, initially a whole host of errors (all algorithm based 'U' codes) accompanied by lots of bonging and lights (suspension, adaptive lights, transmission, park brake, the whole nine yards).
Re-start - most clear; re-start again, all clear.
After a short drive the airbag error is the only one to return:
(U3003-62 |28| Battery voltage - Algorithm based failure - signal compare failure)
I'm thinking I've maybe knocked/dislodged an earth somewhere or disrupted a CAN connection? Odd though that it clears quickly?
I've taken everything apart again at the front and can't see anything wrong.
Lot's of Googling and searching, but nothing definitive.
I'm kind of stumped and hoping the collective wisdom here can assist.
My only other thought was the n/s height sensor that may have got some power steering fluid on it, but cleaned it, put it all back together and seems OK - again, if this was faulty, I'd expect it to be a hard fault.
Thoughts anyone please - starting to drive me up the wall!
Thank you!
Post #696427 18th Jul 2024 9:25am
ballast
Any takers on this one?
Should I assume CAN problem?
Thank you!
Post #696462 18th Jul 2024 8:14pm
ballast
OK, bit of an update on this...
Came away in the RR today. Got back into it at the supermarket and nothing.....
Long story short - pressed the transit/transport switch - everything worked! (I'd noticed the brake lights were on - faulty brake switch? Didn't think that was thing on L322?) Drove holding the switch for a bit and no problem. Eventually could let it go (initially if I let it go, the car would lose all electrics).
Anyone got a circuit diagram for the transit/transport switch? Anyone got any idea WTAF is going on with it?
Thanks
Chris
Post #696512 19th Jul 2024 4:17pm
brake lights on all the time is a thing.
workshop manuals downloads are in the wiki and also do a forum search.. ... - .- -.
Post #696520 19th Jul 2024 8:30pm
