Home > Wheels & Tyres > L405 to L460/L461 wheels
Poleynpo79
Hi, Will the prior generation of wheels from L464/L405 fit on the new L460/L461? Are the offsets similar?
Post #696275 16th Jul 2024 6:27am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Generally yes. The only real difference is the L460/L461 wheels use a bolt rather than a nut and the bolt is a taper fit. So you will need to source new bolts with a flat washer to fit L405 wheels to the L460.
Try this firm https://www.rybo.co.uk/ who supply alloy wheel bolts.
Post #696279 16th Jul 2024 7:32am
