![]() | Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 119 ![]() ![]() ![]() |
A little off-topic: I've tried to turn this bug into a feature.
JPD323 Member Since: 26 Jul 2021 Location: NW Posts: 3 ![]() ![]() ![]() |
It seems these sintered brass filters are becoming harder to find. There are options on Ebay but does anyone know the thread size before I commit to buying? I've seen 9mm banded around but can't find any M9 threads. Are they Imperial? |
It's a really basic standard BSPT (British Standard Pipe Taper) 1/8" male thread on the *silencer, also known as G1/8"
If this is just a vent then the unit is just a silencer and not a filter so drilling it will be the easiest fix at the expense of some noise when lowering the suspension. 2012 TDV8 Vogue (L322) |
It is a silencer.
Stan1971 Member Since: 22 Jan 2024 Location: East Ayrshire Posts: 7 ![]() ![]() ![]() |
So got the same fault on mine. Wouldn’t go to access height, instead goes to extended height. Took out the bronze silencer and everything worked fine again. Obviously the silencer was blocked. So started thinking how to clean it. Saw someone mentioning brake cleaner but i thought why not try kettle descaler. Kettle could do with a clean anyway. So chucked in the bronze silencer into the kettle with the descaler, waited 6 mins and hey ho it was back to brand new. Put it back on and everything is working fine. Kettle is shining too. Thought I’d share it with you as an alternative to drilling a hole. |
timl322 Member Since: 05 Apr 2024 Location: Minehead Posts: 2 ![]() ![]() ![]() |
I had the same issue - drilled a hole in the exhaust filter and the car dropped down immediately. However, it's now sitting down in access mode and won't go anywhere! IID Tool reporting low voltages on two ride height sensors so maybe I need to replace those? |
Sorry it hasn’t been such an easy fix for you. |
