Home > Technical (L322) > 2011 4.4 tdv8 suspension puzzle
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Suspension puzzle
Came out to the car to find the front suspension on the bump stops. Never had any previous issues with the suspension. Jacked the car up and both air bags look in good condition with no cracks etc. when I try and raise the suspension, I get the suspension in extended mode message on the dash, and the rear end raises up into what looks like extended mode, but there are no sounds of leaking air anywhere.
The iid tool is not showing any faults on the system . The only anomaly I can find is that the rear LH height sensor is showing nearly 4volts whereas the other corners are around 1 to 1.5 volts.
The suspension control switches don’t seem to operate as they should. I lowered the rear end using the iid tool deflate function, and when I started the engine the rear raised back up on its own without any input from the controls to extended height, the compressor is pressuring the system ok and the compressor exhaust can be blown through easily so is not blocked.
Mileage is 98000
Completely baffled by all this any suggestions would be greatly appreciated.
Post #695974 11th Jul 2024 11:04am
JayGee
Faulty sensor would be my guess. What are the actual readings of the 4 corners on the GAP IID live values? Also look at what the 4x4 screen is indicating for where it thinks the wheels are in relation to where they actualy are. The Voltage anomoly is also an indication of a fault. 2012 TDV8 Vogue (L322)
Post #695975 11th Jul 2024 11:28am
Dtech
Thanks for the quick response. I’m away from home at the moment , so will check the live values when back,hoping it is just a sensor issue.
Post #695981 11th Jul 2024 12:31pm
mjdronfield
I’d just look at the 4x4 screen as a first pass, as it will show you where the car thinks it is. Then have that in mind when you are then looking at the GAP readings to see if they concur.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #695996 11th Jul 2024 4:38pm
D3Jon
As suggested by others above, a faulty height sensor is the most likely culprit.
But, the sensor could be good, and it's just a broken height sensor actuator rod. Been there.... Smile
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #696001 11th Jul 2024 5:10pm
Dtech
Thanks Jon. I’ve checked , and all rods are connected, and wiring to each sensor plug looks in good condition. I think my next move will be to remove each sensor rod and move them throughout their range whilst checking the corresponding voltage with the iid tool.
Post #696027 11th Jul 2024 10:14pm
D3Jon
Sounds like a good plan.
Also check the supply voltage to each height sensor with your IID. On a faulty sensor I've seen variations from the expected 5.0V reported back.
2014 Disco 4 HSE
Post #696042 12th Jul 2024 9:35am
Dtech
Just an update in case anyone has similar problems. The symptoms were , front end on the bump stops and rear end going into extended height. It turned out to be a fault with the LH front height sensor. When I tested it there was a constant reading of around 0.650 v with no variation when the arm was moved throughout its range. As soon as I unplugged the offending sensor, a suspension fault warning came up on the dash, but the fatty levelled itself out and appears normal, even with the sensor disconnected! New sensor now ordered.
Thank you for the advice from forum members.
Post #696437 18th Jul 2024 12:04pm
D3Jon
Glad you got it sorted! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #696457 18th Jul 2024 7:39pm
