Home > Maintenance & Mods (L322) > Bolt that connects ride height sensor to lower control arm.
MarkO73
Wales 2007 Range Rover Vogue TDV8 Stornoway Grey
Whilst replacing the driver side lower control arm, managed the break the bolt that connects the ride height sensor to it. Does anyone know the part number, or where I can get hold of one? Thanks in advance.
Post #695765 8th Jul 2024 2:39pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
It's not available as a separate part from the sensor, so it's about £130! Shocked
I did the same as you recently, when trying to get the nut undone to replace the lower arms. I fashioned my own version from a stainless bolt and some washers and it works perfectly. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #695822 9th Jul 2024 10:12am
MarkO73
JMC,
Thank you. Glad it’s not just me that has experienced this. Did the same as you, stainless steel bolt, bit of sleeving and washers. Seems a bit ridiculous you can’t get one separately. Fingers crossed it does the job. 🤞
Post #695852 9th Jul 2024 4:43pm
