Home > Maintenance & Mods (L322) > Help With Fault Codes
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi all. My adaptive cruse control has just stopped working but everything else seems to work just fine, well apart from the yellow lines that are displayed when you select reverse do not turn with the steering wheel. I have checked fuses & all seem to be OK. I have also removed the parking module & taken it apart to look for signs of corrosion & that is OK. Does anyone know if the ACC is linked to the parking module? I do have on the dash the adaptive cruse control light continuously flashing.
On my IID tool I get these two codes;
U0159-00 (2A) Lost communication with parking assist control module.
U2003-86 (2Cool Fibre optic communication bus - bus signal/message failed - signal is invalid.
Any thoughts & input welcome, Cheers.
 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #695556 4th Jul 2024 8:07pm
Scouse Exile
This could be a complete red herring but in relation to the fibre optic code there’s a thread elsewhere that suggests to try:
Can’t do much harm to give it a try.
Post #695558 4th Jul 2024 8:43pm
PDC
Cheers for that. But for some reason my car was not fitted with TPMS. I thought it was standard on all FFR but there are no sensors in the wheel arches. The wiring is there however but I can't find the module in the boot either. I know this as I was thinking of retro fitting it. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #695559 4th Jul 2024 8:49pm
Range Rover L322
this is a ghost. A lot of people get it. I ignore it. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #695609 5th Jul 2024 4:17pm
PDC
So it’s the other fault that relates to the ACC fault?
Also should the yellow lines with the reverse camera turn as you turn the steering wheel. Can anyone confirm this please. 👍🏻 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #695615 5th Jul 2024 6:26pm
