Home > Maintenance & Mods (L405) > Rear Seat Base Removal |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 94 |
Look under the front of the seat cushion, there are spring loaded clips that need to be 'rotated' while lifting the cushion, this releases the cushion.
2nd Jul 2024 11:50am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16262 |
I find it easiest using my thumb |
2nd Jul 2024 12:35pm |
I did that.. I also remember it hurting somewhat, must have sensitive thumbs.. |
2nd Jul 2024 12:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35223 |
craig has thumbs made of steel... ... - .- -.
2nd Jul 2024 1:37pm |
batmanreturns Member Since: 16 Jan 2017 Location: Wiltshire Posts: 56 |
Ok, i've tried this and have located the little tabs but for the life of me can't work out if you pull them towards the front of the car, left or right or up?! They just seem locked hard in position. Has anyone got a video or some more advice on how to get these things out?! thanks |
9th Jul 2024 9:18pm |
@batmanreturns it is easiest if you remove the base of the seat by entering the left hand side of the vehicle with you landing up facing the right..
10th Jul 2024 12:47pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1178 |
I found an old tent peg bent at 90 degrees and used that, it did not hurt as much 2017 SDV8 4.4 silicon silver AB
10th Jul 2024 3:14pm |
@tinman, indeed quite brilliant, wish I had thought of that when I first fumbled around trying to figure out this little puzzle whilst loosing skin....
11th Jul 2024 6:02am |
Its easier to remove the seat base to clean the crap that falls between them and away from the connectors. 2017 SDV8 4.4 silicon silver AB
11th Jul 2024 7:42am |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 139 |
Great post, no idea you could do this. |
11th Jul 2024 1:32pm |
zenman it's the only way to get to the various bolts should you need to remove the entire seat mechanism one fine day |
11th Jul 2024 2:15pm |
thanks, great video and i'll give it a go. |
12th Jul 2024 11:01am |
