Home > Maintenance & Mods (L322) > Testing rear shocks |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3122 |
You should be able to tell by the way it handles if a rear shock has failed. Mine were very stiff after 170k miles and could only compress them with my full bodyweight when off the car so unless they have lost all thier fluid I doubt just removing the bottom bolt will tell you anything. 2012 TDV8 Vogue (L322) |
27th Jun 2024 9:17am |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 |
You can get them checked on the vehicle - I have used this service on a 911 previously and if you really wanted to know the actual state of health of your dampers and even how they are matched side to side, then this is the only way to do it scientifically.
27th Jun 2024 9:32am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 528 |
Hi, Another way is to drive over full width speed bumps slowly, say walking speed, you'll tell by the way the car reacts whether one side is damping better than the other. Or of the car bounces excessively then both might be gone, or doesn't bounce at all then one could be siezed, rule of thumb is 1 bounce then settles.
27th Jun 2024 10:44am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7744 |
I understand the CVD shockers default to fully hard if no voltage is applied, or if the car isn’t actually moving….
27th Jun 2024 2:34pm |
