Home > Technical (L322) > L322 tdv8 stored code P2071 but no MIL Light?
pk7976
United Kingdom 2007 Range Rover SE TDV8 Buckingham Blue
Good morning am a new member and also new to the world of landrovers and rangerovers having just bought a 2007 tdv8. More out of curiosity I connected an Autologic Obd2 reader to the car and appear to have P2071 stored despite no warning light on the dash board. A quick google finds DTC Description: Intake Manifold Tuning (IMT) Valve Stuck Closed (Bank 1a) I have tried clearing the code but it does come back so before I start ripping the car to pieces blindly, does anyone have any experience of this or guidance on where to start fault finding testing in situ.
Cheers
Paul
Post #431706 20th Mar 2017 8:07am
Mikey
Vacuum controlled actuators on each inlet manifold alter the length of the inlet tract
As they are vacuum controlled, the first port of call is the vacuum pipework to each actuator. Very common for the pipework to be dislodged when working in the engine. If this all checks out ok, the actuator can be vacuum tested to ensure it is not tight/stuck Thumbs Up
Post #431728 20th Mar 2017 11:00am
pk7976
Thanks for the quick response Mikey! I will have a look tonight weather permitting and report back, am hoping its something as simple as a disturbed pipe but have ordered a mittyvac tester just in case.
I did find another user who had a similar issue but he appeared to just have one valve which was common to both inlet tracts do you think I should expect to find two valves on mine?
Post #431744 20th Mar 2017 1:01pm
Mikey
THere are also another 2, one on each cam cover (inlet manifold is integral)
Just in case we are getting lost in terminology Thumbs Up
Post #431759 20th Mar 2017 2:55pm
rar110
Mikey which IMT works with the EGR, and are they bother vacuume controlled? Thanks ______________________________
Post #431827 20th Mar 2017 9:11pm
pk7976
Had a look tonight and found a small pipe which was not connected but don't suspect this being connected to the main issue as its a small pipe that appears to connect to the back of the air filter housing? regardless its connected back to where I think it belongs. Am not really sure I have found the IMT valves on the inlet manifolds would be really helpful if anyone has a picture where to look?
Post #431862 21st Mar 2017 12:36am
Mikey
Neither. They are seperate electronic controlled flaps in (what would be called) the throttle body, were the upper Intercooler hoses go onto Thumbs Up
Post #431876 21st Mar 2017 11:01am
Mikey
Centre of the photo, small actuator with pipe attached. Same position on the other side Thumbs Up
Post #431878 21st Mar 2017 11:04am
pk7976
Mikey that is brilliant, really appreciate your help! No wonder i could not find them they are buried at the back of the engine and not the front where I was looking.
Will have another look tonight when I get home, am hoping its as simple as a pipe thats been knocked off. Thats the problem when you get a new car its learning what and where all the bits actually are! I remember feeling daunted when i bought a V12 Jag years ago but the Rangie makes the Jag look simple!
Post #431880 21st Mar 2017 11:20am
arturonunez28
Columbia 2008 Range Rover SE TDV8 Bonatti Grey
    Hi friend please can you send photo of the diagram of the vaccum hoses.?
    I need Connect new hoses beacuse the original equipment are not in my car
. Thumbs Up
I am from Ecuador in south America . My car is 3.6 tdv8 diesel 2008 Range Roger Sport.
Thanks
Post #695091 26th Jun 2024 5:12am
