Home > Maintenance & Mods (L322) > 4.4 tdv8 coolant leak
sethfmca
United Kingdom 2011 Range Rover Vogue SE TDV8 Bonatti Grey
Hi all,
I've just developed a pretty big coolant leak on the passenger side, not too sure wheres it's coming from, but before I start to dismantle much more, any hunches or places to look?
Video of the leak here: and https://youtube.com/shorts/xQ-f4Bq7new
Could this be the oil cooler?
Post #695090 25th Jun 2024 11:08pm
JayGee
Difficult to see that close exactly which part of the passenger side engine bay it is. Can you start with a wide shot and them move in? 2012 TDV8 Vogue (L322)
Post #695109 26th Jun 2024 6:35pm
Dolphinboy
EGR cooler?
Post #695174 28th Jun 2024 5:46am
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
When mine was leaking down the nearside it turned out to be the stainless steel pipes that run down there As previously said it’s hard to tell by the video where it is. Anyway mine only happened when hot and under pressure when the tiny pinholes opened up
If it is said pipes then be prepared for a big bill for them. Or if you do a search there’s also a cheap fix with rubber heater hose,as I did 2016 4.4 diesel
Post #695272 29th Jun 2024 6:26pm
