Home > Maintenance & Mods (L405) > ZF8 oil change
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
ZF8 oil change
I didn’t like the idea of the auto box being ‘sealed for life’ as JLR seem to state or at the very least only change the oil at a very high mileage/number of years. The official advice from ZF is that an oil and filter change should be performed at 60,000 miles or at 30,000 in arduous use. So as my L405 has just reached 60,000 I thought I had better get there and do the oil change.
Now, the first issue is that unlike the engine, when you drain the auto box oil from the sump you only are able to drain just under half the total oil. Officially this replacement of half the oil and the filter is sufficient and does count as a service, however I was keen to do more than that. I took the approach of carrying out four oil drains and refills, driving it in between each to let the oil circulate and mix. Auto transmission oil is high in detergent so the new oil does a good cleaning job.
On the fourth drain I also replaced the filter. The oil from the first and second drain was really dark, but the third and fourth looked far more close in colour to the fresh green oil. The filter pan had the usual grey paste/sludge around the magnets and in the filter.
The gear change prior to the service was fine and I had no reason to think a service was required due to the performance of the auto box, however since doing this service it is buttery smooth and changes are imperceptible. I feel it was time and money well spent as proper preventative maintenance.
I would encourage anyone else to think about having the auto box serviced and not treat it as ‘sealed for life’.
Post #694930 23rd Jun 2024 8:07am
Alex1976
For anyone else thinking of doing this themselves you will need:
1. ZF 8 oil. No need to buy the genuine branded item. I bought 20l from Smith & Allan for £100.
2. Oil sump/filter. I bought a genuine ZF item for £110
3. GAP IID tool or similar as you need to be able to monitor the auto box oil temp.
4. Ramps or axle stands for safe working under the vehicle.
5. 10mm and 15mm sockets to remove the under tray to access the auto box.
6. 8mm Allen socket for the fill plug
7. 10mm Allen socket for the drain plug.
8. T40 Torx bit for the sump securing bolts.
9. A torque wrench with a low range - 2Nm to 20Nm
10. Oil pump to feed the new oil into the auto box. I used a small hand pump from Amazon.
11. A container to catch the drained oil. I used a 5 litre measuring jug as it was useful to monitor the volume and colour of the drained oil.
Post #694932 23rd Jun 2024 8:23am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Or pay someone to do a megaflush! FFRR SDV8 Autobiography
Post #694934 23rd Jun 2024 8:40am
Alex1976
Basic instructions/steps you need to carry out:
1. Put the vehicle on ramps/axle stands to provide sufficient room to work under it.
2. Remove the under tray by removing the 15mm and 10mm bolts.
3. Loosen the fill plug on the auto box using an 8mm Allen.
4. Remove the drain plug using a 10mm Allen and catch the oil in a measuring jug (it will be around 3.5 litres)
4a. If not replacing the sump, replace the drain plug and tighten to 8Nm.
5. Once the oil has drained, remove the bolts securing the sump using a T40 Torx.
6. Remove sump and use drip tray to catch last of the oil from the exposed auto box.
7. Inspect the used sump for evidence of metal and debris. Some grey sludge on the magnets is normal wear and not a sign of a problem.
8. Install the new sump using the new bolts supplied. Tighten each bolt until it contacts then tighten with a torque wrench to 10Nm using a cross bolting sequence so it evenly seats.
9. Fill the auto box with fresh oil until oil starts to dribble out of the fill port. It will take about 2 litres.
10. Start the engine and allow it to idle. Ensure the handbrake is engaged and wheel chocks etc are secure!
11. Continue to fill the auto box until oil starts to dribble out again. This will take approx a further litre.
12. Close the filler plug finger tight.
13. Get back in the vehicle and with the brakes firmly applied move the gear shifter through each of the gears, holding each for 10 seconds. Once you reach ‘D’ use the paddles to select ‘2’ and hold for 10 seconds.
14. Select ‘N’ and then increase the revs to 2,000 and hold for 30 seconds. This fills the torque converter with oil.
15. Select ‘P’ and leave to idle again.
16. Using the diagnostic tool monitor the auto box oil temp.
17. With the oil temp reading between 30*C and 50*C you can check the level of the oil again.
18. Undo the fill plug. If oil dribbles out then allow it to do so until it just drips. If no oil comes out, then fill until it does so.
19. Install new fill plug supplied the sump kit and tighten to 35Nm.
20. I like to take it for a test drive at this stage and get it up to temp (auto box oil above 70*C so it opens the oil cooler thermostat). I then recheck the level once it has cooled to between 30*C and 50*C as a final check. Or drain the oil if doing multiple flushes and return to Step 5 above.
21. Replace under tray and tighten the 15mm bolts to 60Nm and the 10mm bolts to 10Nm.
22. Remove vehicle from ramps/stands.
Post #694935 23rd Jun 2024 8:48am
Alex1976
Bodsy or others offering a mega flush is the alternative for anyone who doesn’t want to do the work themselves, but for those who do, hopefully this is helpful.
Most places offering a flush service do not change the filter, and from looking at the filter I took off I am glad I did change it.
Post #694936 23rd Jun 2024 8:52am
garyRR
You can download the ZF service manual and procedure from their website. It has a helpful flowchart and tightening sequence, so you can't go wrong:
https://aftermarket.zf.com/app/controller/...90da53.pdf
Regarding the service kits themselves, if you plan to keep the vehicle long term, go for genuine ZF (the service is a fairly big, mucky job). If you plan to keep the vehicle only a few years, go for aftermarket fluid to save a little money. My personal view is that there's many ZF boxes done 150,000 miles on the original fluid without problem! Unlike a lot of engine oils, I do think it is worth forking out the extra for something that gets changed less frequently.
I got a genuine ZF kit with genuine sump and filter and fluid from a company in Holland for £180 delivered. 2015 Range Rover Autobiography 4.4 SDV8
Post #695024 25th Jun 2024 12:17am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Thanks for that Alex. It's next on my list of jobs. I did my X350 Jag with the 6 speed gearbox last year but it's still useful to read of someone else's thoughts and experiences.
Cheers
Pete
Post #695039 25th Jun 2024 7:44am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
With an expensive gearbox I'd recommend buying the genuine ZF oil which is 4 times the price but.
I used Smith & Allen LSD oil in one of my cars in a new Ford differential and the clutches creaked and moaned on every turn. I replaced that oil with the recommended Castrol Hypoy and the genuine Motorcraft friction modifier and the diff was silenced. True, the S&A was much cheaper.
I did an oil change on 56k miles and there was a lot of grey sludge build up in the sump so I'd recommend that the sump (with its integral oil filter) is changed.
Post #695041 25th Jun 2024 7:55am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Hi all,
I have the service sheet schedule for the SDV8 L405, and the Transfer box fluid is changed every 80K Mile (or 5 years which ever comes first) and the gearbox service is at 160K miles (or 10 years which ever comes first).
Post #695043 25th Jun 2024 8:11am
goldeneye32
Hi all,
Mine is now due the 10th anniversary, although I am only at 110K miles.
Post #695044 25th Jun 2024 8:14am
