Home > Off Topic - Other Cars > 3.0 v6 engine fitment
Big Yorkshire pudding
I wonder if I can pick the forums brains? I'm so pleased with my Range Rover 4.4 tdv8 autobiography that I'm thinking of delving further into the landrover marque by adding a second car to my drive.
I have been offered a friend's lovely 2016 land rover discovery 4 HSE. This has engine failure. But I can obtain a 2020 engine having done 36,000miles to fit in it. But I'm unsure if this will fit as its out of a velar.
Can anyone help with any information as to its fitment??
Thanking you in anticipation. BYP.
Post #694859 21st Jun 2024 8:03pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Assuming it's an SDV6, you then need to check if the Disco 4 is Gen 1 or Gen 2 as the velar unit will definitely be a Gen 2. You cannot downgrade a Gen 2 to Gen 1 spec as the block is different due to the electronic oil pump fitted to the Gen 2 unit. The Gen 2 units are marked around the throttle body area with a Gen 2 label so should be quite obvious. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #694863 21st Jun 2024 8:37pm
Thank you for your kind help on this subject.
Do you know if the turbos, injectors, sump are the same?
The disco I'm looking at has ad blue so I assume that it's Gen 2.
Regards BYP
Post #694865 21st Jun 2024 9:01pm
4RRS
I'm no expert on the Disco 4 as I have a Gen 1 L494 SDV6 & a L405 SDV8, but looking at the parts catalogue the Disco could be Gen 1 or 2 depending on Vin/build date in 2016. Obviously the Velar would be Gen 2. The short block for a Gen 2 D4 & the velar are the same part number but the stripped engine is a different part no. As regards to the sump the part is not available other than buying a stripped engine so I cannot say whether they are the same or not!
If the D4 is Gen 2 then I would say you certainly have a bottom end from the Velar that you could use to rebuild the D4 (assume it has a snapped crank or spun bearings), dont ask me asbout spun bearings in my SDV8, see:-
https://www.fullfatrr.com/forum/topic68615.html
Here's the links to the D4 & Velar parts catalogues: -
https://store.landrover.com/parts/index/hi...and-rover/
Unfortunately my Topix access has expired so I am limited in information that I can pull together!
Hopefully this will give you a bit of help!
Regards
Mike L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #694868 21st Jun 2024 10:01pm
