Home > Maintenance & Mods (L322) > 2012 L322 Aux Driving Lights - Bulkhead Cable Routing
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I've just got myself some nice pair of Cibie Oscar spots in crackle black, the LR fitting kit, a neat switch that I'll fit in the overhead panel by the microphone and some Bevinsee 50w 1500LM H3 LED bulbs to fit.
Question I have is for switcheable power to trigger the relay I need to go from the high beam feed line behind the light unit, into the cabin, through the switch, back out to the engine bay to the relay coil and then on to ground.
My problem is that I can find no easy way through the cabin bulkhead to get into the cabin from the engine bay.
Am I missing something, is there an accessible (high up) bung I could use to route the wiring in / out of the cabin into the wiring bay ? I'd reseal it once the wiring was in.
Picture would help enormously.
Cheers, Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694828 21st Jun 2024 12:17pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
mictuning and I think auxbeam both do wireless kits which get rid of the need to go through the bulkhead if that helps? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #694852 21st Jun 2024 5:41pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
In the past I have used a remote control relay. Made things pretty simple as already had fitted an under bonnet Aux fusebox.
https://www.ebay.co.uk/itm/116140302437?it...BMmpzG54dk 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #694872 22nd Jun 2024 6:47am
Paul H
This is what I am installing on mine
12 Gang Universal Switch Panel, Wireless Cordless, Adjustable RGB Colors Brightness, Multifunction Toggle Momentary Strobe
https://a.aliexpress.com/_EIaLXBD 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #694874 22nd Jun 2024 7:25am
AndyRoo
Hi, yes, I ordered similar but it's causing me headaches with where to put it and it not look like it's an add on.
I'm thinking of something that looks like it should be there, but thanks for the tip.
Post #694880 22nd Jun 2024 9:58am
AndyRoo
Well Censored me senseless, turns out I've been misinformed and spent a load on H3 LED bulbs when it turns out vintage Cibies of are H2s and you can't get an equivalent of 100w H2 in LED form, I really should have checked that.
Looks like the Mrs car's getting an upgrade.
Surprisingly though, you can still get rally spec 130w Halogen H2s, and not as expensive as you might think which surprised me more, every day's a school day.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694886 22nd Jun 2024 2:30pm
