![]() | Home > Maintenance & Mods (L322) > What would you do? SHOCKING!! dilemma |
If you are only saving <£200 do the whole struts. 2012 TDV8 Vogue (L322) |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 116 ![]() ![]() ![]() |
They look remarkably good don’t they!
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Change it all if they are original ones- you’ll only be back in there to change them again at some point so why do the job twice? 2009 (2010 MY) 5.0 Supercharged Autobiography
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Ok so far the advice is pretty clear.
No one can tell you what to do. Depends on your budget, how long you intend to keep the car, how much time you are prepared to spend redoing a strut change and also if you have noticed the obvious signs of shocks becoming worn from how the car handles. Also if you put new shocks on the front you should really consider doing the rears as well…… 2012 TDV8 Vogue (L322) |
That’s fair comment JayGee - the money isn’t the primary issue but they haven’t shown any obvious signs of wear, although new ones might reveal some, and given they look so clean it was at least worth seeking your collective view.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 704 ![]() ![]() ![]() |
The damper shafts / seals may look OK, but unless the car is incredibly low mileage the damper internals will have worn & the fluid degraded significantly.
Thanks Paul, sage advice. The car is 200k + mileage wise so perhaps I had the old rose tinted glasses on for a while after stripping them and seeing how clean they were - I was expecting a rusty shaft 😁
I bought my BWI struts from Island.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
I was one of the ones who voted to only change the bags with a very compelling reason. My arthritic fingers hit the wrong button on my phone |
Loving your honesty cass, fat finger syndrome strikes again.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
If you just do the bags. Getting them to seal 100% can be a bit troublesome.
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 ![]() ![]() |
17 year old struts will be tired, regardless of how good they look. And at 200k miles I'd be surprised if they have much effective damping capability anymore - you can get them tested on a chassis dyno, but I know of only one place in the UK that has such a thing. 2011 Range Rover Vogue SE 4.4 TDv8 |
Ok so bit of an update.
