Home > Technical (L322) > Headlight wiper , out of solutions - need help! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8080 |
My advise would be to bin them both and get some lower headlight trims from an HSE which didn't get the wipers, they always give bother and are pretty much useless anyway... Pete
22nd Apr 2023 11:41am |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Thanks - I’ve never seen the blanking plates.. I thought they all had wipers. Only thing I’m worried about by blanking them is that it’s an MOT failure isn’t it? I thought Bi-xenons had to have a cleaning system and if fitted it has to work 2003 Vogue 4.4 V8 Java Black |
22nd Apr 2023 12:29pm |
Your probably right but I bet not many MOT guys would notice..
22nd Apr 2023 3:26pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
Any car manufactured before September 1 2009 fitted with hid headlights does not require to have headlight washers so if the are missing, removed or not working they cannot fail a mot. ie they are not a testable item.
22nd Apr 2023 8:59pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 577 |
I had the same problem and replaced the pump. It didn't fix the issue and was about to condemn the system and fit blanks.
23rd Apr 2023 11:44am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 779 |
Does anyone know the part number for the pump ( that provides power to the headlight wiper washers ), this is for my 2004 car, might as well try and fix it, before I go on the hunt for some headlight trims at the breakers yards |
20th Jun 2024 4:46pm |
Search for : 67128362154
20th Jun 2024 4:59pm |
Of course - thank you , it's just a BMW X5 part |
21st Jun 2024 12:00pm |
Exactly just like several other parts, for example the flexible fuel hose from the main line to the injectors. I still haven't found the LR number but managed to source it from BMW... |
21st Jun 2024 12:01pm |
