Home > Technical (L405) > Engine cut off while driving and not only
valeriu negara
United Kingdom 2015 Range Rover Vogue SDV8 Montalcino Red
Hi all, I'm new to this forum so please excuse me if about this were discussed else where.
O own a Range Rover L405 4.4 , year 2015 and i facing next big problem ,
The car started with next problem : revs were playing but not all the time , ( only sometimes ) . After that when i was driving the engine showing fault and it stoped working , (every time i have to pull over and start it again) . When we read the fault codes showing FUEL RAIL PRESURE SENSOR.
We've changed almost all FUEL SISTEM , started with both rail sensors from Land rover dealer and NO ANY CHSNGES, after we changed new Hight Pressure Fuel Pump (New from Bosh) ,
then we discovered small Micro Pieces of metal in the Fuel tank and we cleaned it all and changed the Fuel pump from the tank.
Finally i thought that thats it , problems are sorted but...
I driven it about 2 days and it started again revs to play ( but not all the time) and also it started more often to cut off engine on the Motorway or whenever i'm driving.
The engine usually is working as its should and when i waiting at a trafic light or in a trafic the revs start playing and the angine just stop working .
Please if someone know why this is happening or has the same problem please give me an advise because we don't know why it does that.
I'm sorry if something isn't explained as its should but tried to explain with own worlds.
Thank you.
Post #693948 6th Jun 2024 12:13am
GraemeS
Australia
What engine fault codes are stored when it stops? If none then the crankshaft position sensor may be faulty, easily confirmed by logging engine RPM whilst idling with a diagnostic tool which will show momentary 0 or very low rpm.
Post #693950 6th Jun 2024 1:32am
valeriu negara
Hi , the fault shown is
P0087-16 Fuel Rail/system Pressure - Too Low, (only this fault no anything else on the engine )
Please if you know can you give me an advice?
Post #694708 19th Jun 2024 1:41pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Have a look at a thread in 2023 started by bikereacer . It's a problem that I had too, with a simple fix. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #694976 24th Jun 2024 8:28am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have you changed the fuel filter…if you have had debris in the tank/pump the filter could be blocked leading to fuel starvation and limited fuel rail pressure. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #694978 24th Jun 2024 9:28am
valeriu negara
yes i did changed it , two times after pumps replacement , and ill change it again just to be sure but before changing it it done the same thing and after that also .
Post #695000 24th Jun 2024 2:40pm
Chakalisa
United Kingdom 2014 Range Rover Autobiography TDV6 Barolo Black
Did you find a fix to this issue ?
Post #710219 26th Jan 2025 12:49pm
GrandadRob
In my particular case, my problem was solved by the replacement of one simple wire. The problem is that LR decided to use two pieces of wire and join them with a connector, the connector fails. There is a replacement one piece of wire available. There is a LR sheet available. 2013 SDV8 4.4 SE Luxor.
Post #710225 26th Jan 2025 2:38pm
GrandadRob
The LR document is LTB01083 Published on 13/7/2017 2013 SDV8 4.4 SE Luxor.
Post #710226 26th Jan 2025 2:40pm
Chakalisa
Thank you
Where do I get the 1 pager
Post #710227 26th Jan 2025 2:41pm
GrandadRob
This may explain the problem.. LTB01083. 13th July 2017.
Engine hesitation/stall at low vehicle speed.
A customer may express a concern that at low vehicle speed the engine hesitates of stumbles. In some circumstances as a result of the low vehicle speed the customer may report that the hesitation or stumble has resulted in the engine stalling. The engine will restart by cycling the ignition.
If the engine has stalled the customer may also express a concern that :
A) The touchscreen has changed and is now displaying the 4x4 – Terrain response/4x4 information.
B) “D” is flashing on the Transmission Control Switch, and instrument cluster.
C) The charge warning indicator is illuminated.
The customer may also report that, Restricted power mode sometimes appears on start-up.
A Technician may find diagnostic trouble code P088-17,
(Fuel rail/system pressure – too high – circuit voltage above threshold) stored in the Powertrain Control Module.
Cause... Intermittent electrical connection of the fuel pressure sensor wiring harness. Check LTB01083.
Wiring loom portion kit LR085463. (Difficult to find)
Fuel pressure sensor link harness kit LR108438. (Difficult to find)
Some suggest dis-assembling the upper connector and douse it with switch cleaner, then re-assemble. 2013 SDV8 4.4 SE Luxor.
Post #710228 26th Jan 2025 2:44pm
Chakalisa
This is the exact problem and they peformef the following
Requires wiring repair to fuel rail pressure
sensor harness.
parts required LR108438 Link harness.
LR050538 splice connector 3 of.
418-104 glued lined heat shrink 3 of
Was this your final fix ?
Post #710230 26th Jan 2025 2:49pm
GrandadRob
yes, never happened again. 2013 SDV8 4.4 SE Luxor.
Post #710231 26th Jan 2025 2:50pm
Chakalisa
It happened again and now getting another issue
Replace water in fuel sensor assembly with sensor Fault stored and will not clear will need to replace first and recheck.
Headache
Post #710232 26th Jan 2025 2:56pm
