Home > Technical (L322) > TDV8 4.4 Misfire Problem ?? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2377 |
Use a diagnostic tool to monitor engine revs. If the revs momentarily drop to zero then most likely the crankshaft position sensor is failing and if so then it will eventually fail totally. Early engine's sensors are known to fail. |
10th Mar 2024 8:14pm |
RR2010tdv8 Member Since: 10 Mar 2024 Location: london Posts: 8 |
GraemeS
11th Mar 2024 9:37am |
It only has to graph engine speed at idle to do the job. Others with the same issue have immediately spotted the short-term zero rpm bursts. |
11th Mar 2024 11:55am |
Nice - I see my device has a RPM graphing option - I'll try that next! |
11th Mar 2024 1:24pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 184 |
Would it also be worth fuelling with a good diesel like V power and trying something like Dipetane?
11th Mar 2024 1:51pm |
Interesting point about using good diesel and an additive.
11th Mar 2024 2:00pm |
Ya Im paranoid about bad fuel, Ive said this in a previous post but I've never filled up from a small mom and pop type no name garage or the supermarkets. I have always used Maxol, Texaco and Circle K here. If there was a post fuel up incident you at least know they have insurance to cover it.
11th Mar 2024 2:06pm |
I took a trace using the OBD tool and I never see the rpm going to 0.
12th Mar 2024 4:00pm |
The graph doesn't have enough scale to know if rpm does or doesn't drop to zero. The dots along the bottom indicate that revs are sometimes less but you can't tell if it is zero. Can you adjust the display so that idle revs are at least 1/3rd of the way up the screen? It's also possible that your tool isn't capable of showing values for the necessary very short time intervals. If it's showing 1 spot per second that that is inadequate.
12th Mar 2024 9:33pm |
Thanks, GraemeS..
13th Mar 2024 9:44am |
I don't know the sampling rate but the IIDtool does a good job of showing the dropping to zero.
13th Mar 2024 10:48am |
Is it this?
13th Mar 2024 11:27am |
That's the latest version of that tool. They're rather expensive if bought for just one use but I find my earlier BT version invaluable for all that it can do. |
13th Mar 2024 8:52pm |
SOLVED. It was some problem at the fuel tank end with the 2 senders - garage fixed it up and running fine now! |
11th Jun 2024 8:41am |
