Home > In Car Electronics (L322) > Upgrading 2003 head unit to later version
NickHS
Poland 2003 Range Rover Vogue 4.4 V8 Giverny Green
Is it possible to upgrade the original 2003 Vogue head unit to a later version as in the 2006 models?
If so what is required?
Post #693742 1st Jun 2024 6:45pm
mjdronfield
No mate. The 2003 car is based on BMW electronics, cars after about 2005/6 based on Ford electronics. They just won’t work together as the network bus is all different.
You can get an android unit though, but it’s quite a bit of work to strip down and fit.
You can add Bluetooth to what you have using a BMW ULF from an X5 or 5 series.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #693743 1st Jun 2024 7:01pm
NickHS
Thanks very much that clears my mind on that.
Post #693744 1st Jun 2024 7:35pm
