![]() | Home > Technical (L322) > L322 starting issue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The stop-start button has multiple contacts so perhaps the cheap replacement doesn't function adequately.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
You could try a used genuine one & see if that helps….Gentleman of salvage I think are their name, try them? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
L322madhatter Member Since: 31 May 2024 Location: Brighton Posts: 8 ![]() ![]() ![]() |
Thank you both. I've checked the power distribution boards and no corrosion there (unfortunately?). Will keep an eye out for a genuine part |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Have a look at the earth to engine. John
Thanks for the suggestion. Where can I find the earth to engine? |
There is a main one under the right front wing behind the liner. Known to fail and give hassle, try a jump lead as an earth.
That's under the driver's side wheel arch. No obvious earth here unless I'm missing something? 2012 Java Black Westminster 4.4TDV8 |
It's near the bottom corner of the radiator. |
Found it! Cable looks fine but where it connects to the engine/subframe is pretty crusty. Will spend some time on it this afternoon and update, fingers crossed 2012 Java Black Westminster 4.4TDV8 |
Cleaned everything over the weekend, so far 3 starts without faults (pressing any part of the button). Hoping it stays like this but otherwise might try and souce an official start/stop button. Thanks for the help! 2012 Java Black Westminster 4.4TDV8 |
Well, it was fun while it lasted... got about 10 starts without any fault but it's come back again. Any other components I should check or any other ideas as to what it could be? 2012 Java Black Westminster 4.4TDV8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
If the 10 starts was better than before then you are probably on the right track, check the earth lead for corrosion along it's length, does it crackle when you bend it? I've had them fracture before but work now and again as the outer plastic holds the two broken ends together, that lead was in an engine bay and had no earth with a hot engine as the two ends were pulled apart by the heat expanding the outer cable, when the engine cooled down it reconnected... took a lot of searching to find that one, personally I'd leave the one on there alone and fit another earth strap somewhere else... |
