Home > Technical (L322) > ABS ECU coding 03 L322 4.4V8
Antipodean322
Australia 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi all,
I have replaced the ABS ECU in my 03 L322 4.4V8/ZF5HP24 with a unit from a diesel model.
When I use Tool32 to code the module with the DSC_L30 file as per
https://www.fullfatrr.com/forum/topic52951.html
the unit accepts the code but when I check the ECU with RSW All Comms I have a "coding error" fault.
Does anyone have a copy of DSC_L30 that has worked ok for them?
Thanks.
Post #693554 29th May 2024 12:35pm
