Home > Technical (L322) > Turbo shut off valve can it be reconditioned?
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
I have a 2012 tdv8 4.4
I've been told by my mechanic that turbo shut off valve on the big turbo is faulty, he's 30 yrs in landrover main dealers
He's been right so far anytime I've used him
She'll go into limp mode over 2600rpm
Can these units be reconditioned?
£700ish for the new part
Post #693502 28th May 2024 4:52pm
kevinp
Have you checked to see if the COSV valve is free to move? Between Rad and engine at the bottom.
Post #693504 28th May 2024 5:42pm
deltic
No I haven't, is it a vacuum test
Post #693557 29th May 2024 12:14pm
kevinp
It's difficult to get to but yes. You should also be able to move the valve 90' by hand.
If yours has a nut on the end of the rod it is the old type. There is a revised part without a nut.
If yours is stuck try and free it off and see if it resolves your problem.
Post #693560 29th May 2024 12:25pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
The big primary turbo is variable vane, and is on the right hand side of the engine. The smaller secondary turbo on the left hand side of the engine is the one with the turbo shut off valve mounted on the back of it. This controls the exhaust flow to the turbo as required. There is a video as I recall on LR time of the guy stripping one down on his 405 which has the same turbo. But as mentioned above it could be a csov problem
Post #693569 29th May 2024 3:14pm
Fox889
Going over 2600rpm then ‘bong’ is a symptom of the CSOV being stuck. Exactly the same happened to mine, stopped, lock the car, come back in a minute & she’s fine……until the next ‘boot’.
Indie stripped the CSOV (full of oil) and lubricated the shaft & alls well. Worth a look at? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #693605 30th May 2024 6:39am
johnboyairey
If the tiny vacuum pipe that actuates the rod is loose, or off, it will give same symptom. It’s fed down the rear of the coolant radiator.
Post #693703 31st May 2024 6:49pm
