![]() | Home > Technical (L405) > Deployable tow-bar troubleshooting help - gearbox failure? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8004 ![]() ![]() ![]() |
Silicon or PTFE - which should I use ? I usually get so confused that I put it off & then don't do anything, which may be worse than using the 'wrong' one.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
I don't think there's a wrong one between silicon and PTFE for this application - although the PTFE should last longer. The problem with std WD40 is that despite it spraying on well and quickly working in to the areas needing lubrication, its not actually very good as a long term lubricant - ends up just attracting dust/dirt to hang around. The silicon and PTFE versions spray on the same, but leave a coating on the surfaces which acts as a longer term lube - the low friction nature of both materials means they both work well. But just like anything else, they'll get blasted/wiped/rubbed off over time so need reapplying periodically. Mike - MPx
Thanks - I'll order a can of PTFE |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 90 ![]() ![]() |
Rinsed with lots of water and sprayed with rust-dissolving spray.
Finally received the motor and gearbox on Wednesday.
Duplicate |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3898 ![]() ![]() ![]() |
I thought mine was goosed (technical term) as it failed to deploy (or retract for that matter) a couple of times. I just keep trying, holding the button in (not the on/off button) as apparently it delivers a volt or two more to the towbar motor and so far it has always worked for me.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
I had a similar issue with the deployable towbar on my F Pace. It repeatedly failed to go back into the stow position and I was sure it was going to be an expensive fix.
I finally had time to fix it today.
Good result |
My thinking was that I’d rather have a spare motor and gear case collecting dust than have to assemble and disassemble twice.
When trying to deploy the tow-bar one week later, it was stuck again. This time, a strong pull by hand was enough to help the motor and get the tow-bar to deploy.
After not using the tow bar between mid December and end of February, it was stuck again. I went through the procedure of bumper removal, greasing what is accessible from above, followed by re-assembly. Then I used it intensively for a weekend, retracted it and drove 160 km round trip in winter conditions the following weekend.
