![]() | Home > Maintenance & Mods (L322) > New style bluetooth module as standard on a 2008? |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
The later Disco Bluetooth only has the +ve and -ve connections and if the radio works it’s likely the Bluetooth does too. Phone not fitted suggests your phone is not paired.
Covbandit Member Since: 10 Jan 2016 Location: Coventry Posts: 108 ![]() ![]() ![]() |
Yh it has the 2 wires only but this is not a disco aftermarket, this appears to be factpry fitted, only 2 wires in the plug and only 2 wires in the loom, so it is mot a retrofit. I was under the impression an 08 range rover would still have the nkia style bluetooth, this even has the correct bracket to hold the bigger bluetooth unit in, not some double sided tape or cable ties. To pair it says put bluetooth on phone in pairing and enter number, but car not sending any bluetooth signal at all. My 05 says exactly the same on the screen, phone not fitted and the bluetooth on that one is bypassed. So I think this unit may have gone faulty, I am going to try and reflash the bluetooth module tomorrow using my iid tool, see if that helps?
