Home > Technical (L322) > L322 3.6 TDV8 - Engine System Fault |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 |
17th May 2024 7:29am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Crash sensor active? - this sounds like a sytem to stop the engine running after a collision so there must be some way to reset it. 2012 TDV8 Vogue (L322) |
17th May 2024 7:50am |
That was my thought as well. The battery were not tightend sonit could move a bit inside the battery-room (?). All tho I can read the same fault on my other L322 TDV8 which runs great.
17th May 2024 8:02am |
Did some more checks this morning. It throws B10A2-36 fault which is related to the «crash inertia faul» according to TOPix. All tho the problem is that its pretty much impossible to find the switch. If the car has one. TOPix says its between the ECM and RCM which makes sence, but where the heck is the switch?
25th May 2024 2:17pm |
Ok. Got some more time to do re-search on the car in question.
29th May 2024 4:54am |
Have done some more reaserch on this matter.
11th Jun 2024 3:59pm |
Another update to this matter.
12th Jun 2024 8:26am |
Another update.
13th Jun 2024 8:51am |
KangaBen Member Since: 06 Nov 2024 Location: Melbourne Posts: 1 |
Hi Mads, did all of this fix your issue? |
6th Nov 2024 2:59am |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 |
8th Nov 2024 8:03pm |
