Home > Maintenance & Mods (L405) > Remote start L405
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Remote start L405
I’m thinking of fitting a remote start to my car…, but the system I have requires several main connections to the ignition.
Accessory:Allows you to power accessories like the radio without starting the engine.
On: Powers the vehicle's electrical systems without starting the engine. Dashboard lights and other electrical systems are active in this position.
Start: The starter motor engages, and the engine begins to run.
Is there anywhere I can splice easily into these as the cars start button only appears to have acc and start..?
Thanks
Post #692809 16th May 2024 7:50pm
Why do you want it ?
Have you considered the insurance implications ?
Power without the engine running shuts down for a reason - it flattens the battery fairly quickly on an L405.
If you want to pre-warm the engine, search for threads containing FBH.
Post #692827 17th May 2024 8:09am
