Home > Technical (L322) > 2010 4.4 tdv8 boost problems |
tabbahenry Member Since: 22 Mar 2016 Location: shetland Posts: 5 |
16th May 2024 4:59pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
https://www.fullfatrr.com/forum/topic60579.html
16th May 2024 6:07pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
this might be it
16th May 2024 6:32pm |
My fault appears in the low revs and boost like just after top of a hill and the revs is under 1500 to 1000 rpm. I can find no damage on the pipes to the bypass valve . And am seen it open and close . So am thinking the bypass is OK and she dosnt go into restricted performance when you drive her hard with high boost . So I lean more and more to the primary turbo. |
16th May 2024 6:41pm |
