Home > Technical (L322) > Restricted performance |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 |
Would appreciate any help that can point me in the right direction.L322 5.0 supercharged has thrown a P0458 fault code. This apparently is the purge valve. Having recently moved to the Isle of Wight none of the Land Rover
15th Dec 2021 3:30pm |
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 27 |
Did you ever get to the bottom of this? Mine just produced same code. 2010 Supercharged |
14th May 2024 4:02pm |
Hi Alex, have to be honest it was a while ago. What I do remember is when I picked car up it threw the code again within 1/2 a mile. Went back and Fitter changed a 15 amp fuse in the engine bay. If I remember correctly it was 5th from the left when facing engine. I had to do it one more time a week or so later and not had it show again.
14th May 2024 4:42pm |
Hi Alex, only thing I have is written on piece of paper
14th May 2024 7:45pm |
I owe you an internet beer, thanks Dave. The F5 fuse had blown, still had the restricted performance message on first startup but second startup a few hours later all warning lights were gone
15th May 2024 6:27pm |
Hi Alex, excellent mate glad it worked.
15th May 2024 6:31pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 806 |
yes I believe that codes P0458 P0489 and P0695 are all related to the F5 fuse in the engine bay fuse panel |
15th May 2024 8:06pm |
winco Member Since: 12 Feb 2024 Location: Dorset Posts: 34 |
I concur. P0458 with non start. Fuse F5 15A had blown. Replaced fuse and P0458 fault code gone. 2010 5.0 SC Autobiography Overfinch in Bentley Silk White pearlescent, 22" Overfinch wheels with 285/35x22 tyres |
8th Aug 2024 4:55pm |
