Home > Wheels & Tyres > L322 21 inch spare wheel
sjn
England 2012 Range Rover Vogue 4.4 V8 Orkney Grey
Good afternoon,
2010-12 L322
Does a 21 inch spare wheel fit in boot???
275 45 21 spare wheel fits spare wheel hole but boot floor is not fitting flush Shocked
Am I doing something wrong? Dyslexic, so please bear with my grandma and spells.....
Post #692621 14th May 2024 1:52pm
JayGee
Same diameter but 20mm wider then mine ( 255/55 R20) so they should fit but that extra width may be a problem. Have you removed inserts for the spacesaver? 2012 TDV8 Vogue (L322)
Post #692627 14th May 2024 3:12pm
sjn
Had a full size 20inch spare.... Dyslexic, so please bear with my grandma and spells.....
Post #692629 14th May 2024 3:44pm
JayGee
You may have to partialy deflate it to squeeze it in 2012 TDV8 Vogue (L322)
Post #692630 14th May 2024 3:52pm
sjn
I was thinking, should I let some air out it as I do carry electric pump in the L322 all times but this is going backwards.... Wondering if anybody had done any mods to make a 21 inch fit flush? Dyslexic, so please bear with my grandma and spells.....
Post #692649 14th May 2024 6:17pm
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I can answer this.
I have LR 101 wheels on 06MY L322. They are 21x9.5 rims with Pirelli 275/45/21 tyres. The spare fits perfectly in the spare wheel well. You may find you’re not locating the cover properly.
 Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs
Post #692651 14th May 2024 6:35pm
sjn
Snap same wheels Embarassed Embarassed Embarassed Have taken the wheel in and out few times will have a look at the cover Thumbs Up
Post #692656 14th May 2024 7:36pm
RogueRanger
Looks great!
The cover is a bit fiddly. I suggest the first thing to check is the spare wheel pull handle. Make sure it’s sitting shy of the rear lip of the wheel well. Then, if you look at the underside of the cover, not far in from the tailgate end, there are two pins pointing outwards either side that finish flush with the edge of the cover. As you lower the cover over the wheel well, make sure they are aligned with the clips they are designed to lock in to. I’m sure you’ll be fine.
Good luck! Des
Post #692660 14th May 2024 8:08pm
Andy
I’ve got 21” and the spare fits. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #692726 15th May 2024 3:58pm
