Home > Wheels & Tyres > Recommended Tyres
fisha
Whilst not full emergency braking conditions, between the Pirelli 20” tyres and the radar 22” AT tyres, I have to admit that its been the Pirelli scorpions which have been the ones that felt like that they have let go first. For example braking and turning into a roundabout there have been a couple of occasions where it felt like it was losing grip and understeering on the turn in. But I’ve not had that happen with the AT’s.
Similarly when climbing a hilly road and going round a switchback, the system has stepped in the DSC a couple of times. And I dont really feel I’ve been pushing the car hard when its happened.
I will admit though, there is quite likely sub-conscious driving it easier knowing when your on AT because of the reported grip level differences … but the understeer / DSC cut ins have been unexpected on the road tyres … to the point I cant say that I feel I can drive round in confidence based on the thought “road tyres are better in wet”. V8 or else ...
Post #692454 12th May 2024 1:38pm
StuManchu
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
That's exactly what I had with the scorpions, but as soon as I swapped to the Radars no issue under the same.condirions, like you say you adapt your driving accordingly knowing you have AT's on, will they stop on a dime If someone hard breaks in front of me? Who knows, but regardless of of tyre, how quick will a near 3 tonne Rangie stop anyway? Having driven artics for the last 20 years, I guess I drive in a different manner than most anyway, justy 2 pennies worth....
Post #692458 12th May 2024 2:24pm
JayGee
If anecdotal experiences show A/T tyres outperforming road tyres in the wet on tarmac in identical circumstances all I take from that is the circumstances were clearly not identical. This is not even up for debate - A/T tyres cannot grip as well on tarmac as road tyres by the nature of the tread. If true the opposite argument would be valid and there would be no need for off road tyres or road tyres - there would be just tyres 2012 TDV8 Vogue (L322)
Post #692467 12th May 2024 3:53pm
fisha
JG, I'm fully aware that 'road' tyres perform under test better than 'AT'. I'm not debating that aspect, and yes its 100% that the circumstances were different ... unless its test environment, they always will be different. I'm not saying either than AT's don't break traction either ... they absolutely do.
However, across long periods of general driving my anecdotal experience is that for my driving (and I don't rag it about), I have found that the road tyres have been the ones I feel have broke traction in an unexpected manner compared to the AT ones.
Is it that I'm compensating my driving when using AT's ... perhaps ... this is no bad thing, driving to the conditions I suppose.
But I also wonder whether there is an aspect that the road ones are holding on better for longer, but when the break traction, they do so in a snappier manner, so dont give as much warning. On the other hand, the AT tyres might break traction earlier point, but do so but in a more linear manner which allows you to feel that break coming on adn increasing, and so you can react / adapt to the driving. V8 or else ...
Post #692471 12th May 2024 4:38pm
Sandyt
Interesting I had Pirelli's on and swapped them after a couple of months they were very quiet and comfortable but didnt have the performance in the wet for my style of driving - I changed back to Michelin Pilot Sports which I do think are the best road tyre for my driving.
I will say I have never driven the 322 on AT's as have no need but wouldn't choose them for the road work I do - so each to their own I change mine at 4mm because by then they have gone off
Post #692577 14th May 2024 6:55am
JayGee
I wouldn't argue that tyres have different breakaway behaviour in a corner but in an emergency stop in the wet you just need outright best grip IME. Also I'd agree that the Pilot sport ( or any premium summer road tyre) will outperform a Pirelli A/S tyre in all but the coldest conditions as that's the compromise of summer tyres vs A/S. Looking back I'd have probably got away with just running a premium summer tyre like the PS although there have been a few occasions in the highlands and last years Lake District snow bomb event when I was glad I had A/S fitted. 2012 TDV8 Vogue (L322)
Post #692586 14th May 2024 7:47am
Sandyt
Absolutely agree I run Goodyear Ultragrip in the Winter as I am in France and Germany a lot of the time
Bet summers in the snow are fun haha
Post #692594 14th May 2024 9:15am
Bolert
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Sorry to drag up an older post, I went down the GG AT3 route a month back.
1500miles in and all good and highly recommend.
Comparison image between the Pirelli and the GG as well.
 2012 4.4 TDV8 AB Sumatara Black with Ivory / Jet interior
Post #701304 2nd Oct 2024 4:58pm
jez676
What sort of miles are people getting from the AT3’s compared with road tyres ?
Post #703686 3rd Nov 2024 5:59pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I have run both scorpions and AT3s on my MY11 4.4
50k+ miles experience on both sorts
AT3s
better off road / grass
Slightly better life
Cheaper
3 mountains stars for winter use (but never tested so can’t comment)
Zeros Noise Cancelling
Quieter
More grip IMHO on road in dry and particularly in wet
Better MPG (marginal)
Softer over bumps
Currently on the zeros…I don’t do that much off road any more - so happy with zeros
I have needed to emergency brake on both types of tyre
I found the combination of ABS and wet / greasy road made the events “more interesting” on the AT3s
Post #703818 5th Nov 2024 3:27pm
