Home > Maintenance & Mods (L405) > 2016 L405 with auto tart stop Diff refill
Extol
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
Hi,
I was renewing the Diffs and transfer case oil to find the rear diff fill point is not what I found on the Service Manuel or the videos online. mine it was towards the front of the Diff and at a much higher location. so when I drained i was able to drain 820ml but on the fill i was able to fill the whole 1 litre.
still not sign of a drip. then I stopped and took about 150ml out so I keep as close to what I took out.
is this correct ?
Post #692337 11th May 2024 8:47am
dhallworth
In the workshop manual for the L322 it says to fill it when the required quantity of oil and that the fill plug is NOT a level plug. It also states that using it as a level plug could cause damage. I'd imagine the L405 is the same.
It sounds like you've overfilled yours I'm afraid.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #692399 11th May 2024 8:55pm
