![]() | Home > Technical (L322) > A/C Gas Recharge - How many grams for my car ? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 513 ![]() ![]() |
Those controls are for the front only air con - so 700g is correct for your vehicle.
Oh, BTW - Your controls are not just for the blower fan, but will also vary the amount of hot-coolant making it to the rear heat exchanger via an electronically controlled valve in the engine bay.
Big E Member Since: 16 Jan 2016 Location: Manchester Posts: 6 ![]() ![]() ![]() |
Hi Jon
Also
Ah, ok.. my misunderstanding on that button. Thinking about it my earlier L322 had that switch as well and it didn't have 4 zone climate. It's just to stop rear passengers (kids) messing with the heat control / fan speed. I'm 100% certain, you don't have rear air-con. Those pictures were of my 2011 Vogue SE (now gone), so if you had 4 zone climate, you'd definitely have those controls. Put your VIN into the link below, it'll give you the build spec of your car as a huge block of text. Read through it to see if you can find reference to climate zones. https://www.vindecoderz.com/ I think that the blue / red marking on the temp knob just indicate which way to turn for hotter / cooler. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Whilst the 2011 brochure doesn't cover the Westminster, I just checked it, and 4 zone climate was an option on all cars, even the Autobiography.
If your AC is not working properly the usual culprit on these models is the compressor and not low refrigerant 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Put the front on full hot, put the rear on full cold... if it's icy in the back you have four zone...
