Home > Maintenance & Mods (L405) > Aux belt length missing out Active Dynamics Pump |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2427 |
Not that its of any help to you, years ago I had a belt to bypass the ACE pump on my TD5 D2 for remote area touring in case the ACE pump failed. Some trial and error in getting the length acceptable and trimming 1 rib from a wider belt was required, as none was available in an acceptable length and with the correct number of ribs. It worked even though it didn't wrap around the power steering pump pulley to the extent of the original belt although it wasn't ever put to use. |
10th May 2024 9:47pm |
