![]() | Home > Maintenance & Mods (L405) > Deployable steps versions and upgrades |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 77 ![]() ![]() ![]() |
My deployable side steps are starting to show their age and its lead me down a bit of a rabbit hole.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
handy info, thanks |
Sundayjumper Member Since: 15 May 2024 Location: Berkshire Posts: 15 ![]() ![]() ![]() |
I've only had my car a fortnight but I'm already paranoid about the side steps packing up. Is there a maintenance how-to anywhere ? Or is it pretty self-explanatory when you look at them ? I fancy pulling them all apart to clean & lube as necessary. |
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 44 ![]() ![]() ![]() |
Me Too, I've just bought a 2016 L405 SDV8 AB and one of the steps won't deploy properly, had a quick look but not sure where to start |
Number one thing not to do is grease them or apply any kind of sticky lubricant. Grease has its place in mechanisms but exposed on the underside of the car isn't one. It'll get grit in it from the road and becomes a grinding paste. It will make short work of the graphite in the bearings and accelerate the wear from there. Keep them clean is your best bet, they are designed to have dry lubrication, if you wanted a suitable spray use a dry one like moly spray.
