Home > Maintenance & Mods (L405) > can anyone help estimate cost for these on an L405 ?
Nick V8
These are flagging up on the last MOT, but still passed.
L405 V8
Can anyone suggest a rough ideas of cost to get them done at main dealer ?
Nearside Front Brake disc worn, pitted or scored, but not seriously weakened Inner face (1.1.14 (a) (ii))
Offside Front Brake disc worn, pitted or scored, but not seriously weakened Inner face (1.1.14 (a) (ii))
Nearside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Offside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
cheers,
Post #692063 7th May 2024 11:14am
garyRR
By the sounds of it, it's a vehicle you're interested in purchasing, in which case you shouldn't hold servicing items against the seller.
Regardless, main dealer would charge you silly money and it would be un-necessary to get such jobs done at a main dealer.
Brembo discs and pads will cost c. £200 for the parts plus around 1.5 hours labour.
Most garages will want to replace the whole arms instead of just the bushes. The suspension arms cost about £100 each (but it does depend which one - an MOT advisory won't always give that level of detail). Labour is anywhere from 45 minutes to 2 hours per arm depending on how stuck the ball joints are.
So, including parts:
Independent garage: £650-800
Main dealer: £1,250-1,800 2015 Range Rover Autobiography 4.4 SDV8
Post #692104 7th May 2024 7:01pm
Mikey
Budget £750-800 at an indy. Bit cheaper if using non OE spec parts Thumbs Up
Post #692113 7th May 2024 8:39pm
CS
Mine had scored etc front discs from about the first service, it was agreed that the discs would be replaced when the pads were due for replacement and that happened at about 60,000 miles. Cost then included brake caliper refurbishment/replacement so total £1171
Both front lower arm bushes were replaced at the same time, cost £705. Also both front ARC bushes £476. Only Range Rovers since 1988
Post #692115 7th May 2024 8:44pm
Sundayjumper
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Discs & pads are pretty easy to do - get your hands dirty and save a few hundred quid !
Suspension arms might (or might not) be difficult. Defer to an Indy if you're not confident.
Absolutely no need to go to a main dealer for either.
Post #693287 25th May 2024 9:11am
