Home > Technical (L322) > Drops overnight, but NOT when battery disconnected
Eirik34
Norway
Hi, the L322 has started dropping overnight - rear to the full bottom, front just halfway down. Two days ago I disconnected the battery after rising it up to normal hight, and after the compressor had filled up the reservoir. The compressor is 1 year old.
After 2 days standing with the battery disconnected, it hasn't lowered anything, all corners look 100% fine! So no air leak, but what can cause the car to lower when the battery is connected? L460 P550e AB SWB MY24
Sold: L322 TDV8 Vogue MY07
Mini Cooper S Convertible
Post #691744 2nd May 2024 10:25am
JayGee
Almost certainly a faulty height sensor which is giving an incorrect height value to the ECU which then tries to level the car after shutdown. Have a look at the 4x4 screen and see if one of the indicator marks is off level 2012 TDV8 Vogue (L322)
Post #691747 2nd May 2024 10:37am
Eirik34
Norway
Thanks Jay, will try that. Do you know if this also should be noticeable in the Gap IID tool? I used that tool to adjust the height just before I disconnected the battery, and the GAP IID tool was able to adjust the height with 10 mm down and up (all corners) without any problems. But maybe that could still be done with a faulty height sensor? L460 P550e AB SWB MY24
Post #691753 2nd May 2024 11:47am
JayGee
Even better if you have the GAP tool. Do a guided calibration and see whay happens when left overnight? 2012 TDV8 Vogue (L322)
Post #691754 2nd May 2024 12:34pm
Eirik34
Norway
Hi Jay, I re-calibrated the height yesterday using the "Guided tour" in the Gap tool, and it didn't loose any height overnight. Couldn't see any obvious errors of the height sensors constants displayed in the tool during the process.
Edited:
BUT, after the car has been standing today, it has now lowered again. Weird!
I'll try to replace the relay, and then try again leaving it overnight. L460 P550e AB SWB MY24
Post #692008 6th May 2024 11:23am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
problem could be a worn seal in a valve block had a similar problem myself ,got a valve rebuild kit from 4x4airseals.com around £18-20 takes about hour and half to two hours . Thumbs Up
Post #692040 7th May 2024 3:26am
Eirik34
Norway
On Monday evening I replaced the relay for the air suspension, and the car has been parked since. No air leaks and car still levelled at the correct height for all 4 corners.
So I guess that it must have been just a faulty relay that caused the car to drop to the absolute bottom.
Or could it still be an intermitted seal leak in the valve block, Will? L460 P550e AB SWB MY24
Post #692131 8th May 2024 8:41am
will308f
well fingers crossed all sorted ,if so nice easy quick cheap fix Thumbs Up
Post #692136 8th May 2024 9:43am
Vic
Netherlands 2007 Range Rover Vogue TDV8 Java Black
I have had the exact same problem since a week. has replacing the relay finally solved the problem for you?
Post #693934 5th Jun 2024 6:48pm
Eirik34
Norway
Yes, for our car it was just the relay. No "air leaks" (dropping suspension) since I replaced the relay. L460 P550e AB SWB MY24
Post #693947 5th Jun 2024 9:27pm
TDV8 Paul
Good fix- what made you look at the relay? 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #693985 6th Jun 2024 2:39pm
Eirik34
Norway
I recently (1 1/2 year ago) replaced the air compressor, and had kept the previous relay - thought that it might be the next thing to try, given that the car didn't lower when the battery was disconnected. L460 P550e AB SWB MY24
Post #693997 6th Jun 2024 6:02pm
