Home > Technical (L322) > 4.4 TDV8 GearBox Leak |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2760 |
Could be leaking from the gearbox pan seal. the electrical plug or the cooler and pipes. Maybe worth trying to see if you can identify exactly where as if it's draining away you won't be able to drive it. 2012 TDV8 Vogue (L322) |
28th Apr 2024 1:40pm |
rhjackson Member Since: 26 Apr 2024 Location: Devon Posts: 4 |
Thankyou. I had a look and could not see any wet areas. Maybe it only leaks when the gearbox is hot. It did smell like a clutch smell initially which made me look underneath (i know they don't have clutches but similar smell)
28th Apr 2024 9:35pm |
