Home > Maintenance & Mods (L322) > Front Air Suspension
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Can anyone recommend the best place to get the complete front airbags and struts from? Can hear a leak coming from my front drivers one and checked the bag itself and it's not leaking anywhere so think the strut itself has failed
Post #691472 28th Apr 2024 5:33pm
JayGee
The strut hasn't 'failed' unless it's not damping or throwing a fault. You can just change the air bags which is a lot cheaper than doing the whole strut esp on the CVD dampers. 2012 TDV8 Vogue (L322)
Post #691474 28th Apr 2024 6:54pm
JoshVogue94
I'm getting the yellow suspension fault and the codes C1130-66 and C1A13-64 mate
Post #691477 28th Apr 2024 7:15pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
But then you will have new bags and old struts that will faill sooner than later.
Just avid arnott, bilstein or oem will be ok.
Post #691495 28th Apr 2024 9:05pm
JayGee
AFAIK those codes tell you somthing is wrong with the air suspension system and not the strut ( shock absorber part) itself and the last code is to do with the compressor not venting fast enough. 2012 TDV8 Vogue (L322)
Post #691510 29th Apr 2024 8:21am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Just be aware if replacing the strut that the Arnott 'CVD' struts have been shown based on evidence on here to not actually be CVD struts. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #691516 29th Apr 2024 9:16am
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
The ones from Aerosus are pretty good and a lot cheaper than anywhere I could find within the UK, they also only take 48hrs to deliver! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #691519 29th Apr 2024 9:32am
JayGee
Fitted a pair of Aerosus to the front of mine but looking back now I would have just replaced the bags as the old shocks were still working fine. Even though Aerosus are definatley the cheapest option it's still an expensive part so depends on how much you want to spend and how much you can DIY. Changing the whole strut is easy enough but to change the bags you need a workshop and a clean area and have a lot more time available to do the job. 2012 TDV8 Vogue (L322)
Post #691524 29th Apr 2024 11:34am
